Schroeder Industries Introduces Handy Filter System Basic Cart | HFS-BC
July 2016 -- Leetsdale, PA
{image:1}
Schroeder Industries, a recognized leader in filtration and fluid conditioning products, introduces its new Handy Filter System Basic Cart | HFS-BC with Dual Housings and HFS-BC Backpack Version.
Schroeder's Handy Filter System Basic Cart is a compact, self-contained "light-duty" filtration system equipped with high efficiency, high capacity GH elements capable of removing particulate contamination and/or water quickly, conveniently and economically. It is perfect for cleaning up existing systems as well as for pre-filtering new fluids, since new fluids often have contamination levels significantly higher than that recommended for most hydraulic systems.
{image:2}
The HFS-BC's compact, lightweight design with replaceable element cartridge has a 25% higher dirt holding capacity than comparable spin on filters. GH9 Element service is easily accomplished through the top-ported filter housings. The bypass valves and sealing of the housing are renewed with every element change. The 4 GPM gear pump is capable of handling fluids up to 1,600 SUS. The optional dual filter assembly allows for water and particulate removal or true staged particulate. The HFS-BC Backpack option will allow for a greater ease of transport across large distances.
About Schroeder Industries
Schroeder Industries, an ISO 9001: 2008 certified company, designs, manufactures and markets filtration products for the hydraulic and lubrication, filter systems, process and fuel industries. Their expertise in filtration technology, superior filter and element technology capabilities, dedication to customer service and product support are the reasons Schroeder is a worldwide leader in Advanced Fluid Conditioning Solutions®.
