Maintaining Shaft Alignment – Base Component Reliability
Maintaining Shaft Alignment - Base Component Reliability
by Everton Tobar Silva, Henkel and John Borden, Loctite
The effects of shaft misalignment are well-published and documented. The issue is real, recurring, and, in many cases, it can be significantly reduced. This presentation will focus on a common cause of misalignment; effects; RCA using 5 Whys; and review key learnings.
TAKEAWAY: How base components can affect overall equipment reliability using RCA.
