Sherborne Sensors Debuts A640 Series Precision Solid State Accelerometers
Available in ranges from ±1g to ±20g with ±5Vdc output, the Sherborne Sensors A640 series features an advanced solid-state MEMS sensor, incorporating integral air damping. Unlike fluid-damped devices, air damping is essentially independent of temperature, which enables the accelerometer to reliably perform over a very wide temperature range (-40° to +100°C), with essentially zero temperature coefficient of damping ratio. Units are compensated for effects of temperature on both sensitivity and zero, and incorporate positive mechanical stops, conferring excellent shock resistance.
The Sherborne Sensors A640 series range is designed to operate from an unregulated DC power source and offers a high useable frequency response. An unfiltered output offering a usable frequency response up to 600 Hz and an additional 5Hz low pass filtered output is standard on all units. . Signal ground is isolated from power ground. Electrical termination is via a military-style, Bayonet lock connector. Units may be supplied with the output biased at 1 g, to offset the effect of gravity.  Other model variations are available upon request.
Typical applications include data acquisition systems, crash recorders, fatigue life monitoring and prediction, road bed analysis, mass transit system monitoring and deceleration control, high-speed railway fault detection equipment monitoring, military and civil flight simulators, autopilots and low-frequency vibration monitoring.
All Sherborne Sensors A640 series accelerometers are 100% tested and calibrated at the factory prior to shipment, and are accompanied by a two-year comprehensive warranty.  The product is also included under the new Sherborne Sensors Guaranteed On-Time Delivery program. For additional details, drawings and specifications, please contact Sherborne Sensors toll-free (in the US & Canada) at 1-877-486-1766, nasales@sherbornesensors.com, or on +44 (0) 870 444 0728, sales@sherbornesensors.com   (worldwide), or by visiting www.sherbornesensors.com.
About Sherborne Sensors:
Sherborne Sensors is a global leader in the design, manufacture and supply of high-precision inclinometers, accelerometers, force transducers and load cells, rotary encoders, instrumentation and accessories for industrial, military and aerospace customers. Products offered under the Sherborne Sensors brand are renowned for their ultra-reliability and long-life precision within critical applications. Recent acquisition of synergistic technologies by Sherborne Sensors within our inclinometer and force and load cell offerings has allowed customers to benefit from expanded product lines, with added benefits of engineering support, global sales presence, repair, refurbishment and calibration services, stocking programs, and continuous product improvement.
