Silicon Designs Introduces Universal MEMS Capacitive Accelerometer Modules
Available in eight different models and in both single axis and triaxial versions, the Silicon Designs 60 Series features measurement ranges from 2 g to 400 g. These rugged, lower cost sensors offer reliable high-precision shock, vibration, and acceleration measurements across a broad range of automotive, aerospace, industrial, power generation, and test and measurement applications.
Design of the new 60 Series combines either a single model, or three orthogonally block-mounted models, within a single epoxy seam-sealed anodized aluminum housing. Silicon Designs’ 100% in-house manufacturing and rigorous testing processes, along with the incorporation of additive micromachining and integrated circuit technology, result in a highly reliable MEMS capacitive sensor tailored for zero-to-medium frequency instrumentation applications. In addition, the company’s own proprietary manufacturing technology allows for on-board voltage regulation and an internal voltage reference, making the units relatively insensitive to temperature and voltage changes and eliminating the need for external power amplification and regulation.
All modules are easily mounted to a test article or fixture via glue, epoxy, or two #8 or M4 screws. Carefully regulated manufacturing processes ensure that each sensor is consistently made to be virtually identical, allowing users to swap out modules with little or no testing modifications, saving both time and resources. This also allows test engineers to provide a quick plug-and-play solution for almost any application, with total trust in the accuracy of sensors used within published specifications.
For details, drawings or additional information about the new 60 Series or other products available from Silicon Designs, visit www.silicondesigns.com
