Smart Vision Lights Introduces Line of Machine Vision Filters
Among the products in the new filter line are bandpass filters for blue, cyan, green, amber, red, and deep red LEDs; colorpass filters in the red and deep red; an infrared bandpass filter used to maximize contrast under IR lighting; and a linear polarizer used to eliminate glare. The latter product comes with rotating locking screw to maximize versatility.
The wavelength range for each filter is as follows:
  • Blue bandpass: 440nm - 480nm
  • Cyan bandpass: 470nm - 515nm
  • Green bandpass: 500nm - 540nm
  • Amber bandpass: 580nm - 610nm
  • Red bandpass: 620nm - 660nm
  • Red colorpass: 610 nm - 680nm
  • Deep Red bandpass: 650nm - 680nm
  • Deep Red colorpass: 640nm - 680nm
  • Infrared bandpass: 840nm - 870nm
  • Linear Polarizer: 400nm - 700nm
Smart Vision Lights is also offering a step down adapter from 27mm to 25.5mm and step up adapter from 27mm to 30.5mm.
For more information on the bandpass filters other industrial and machine vision LED lighting products from Smart Vision Lights, visit SmartVisionLights.com.
About Smart Vision Lights
Smart Vision Lights (Muskegon, Mich.) is a leading designer and manufacturer of high-brightness LED lights for industrial applications, including machine vision. Smart Vision Lights products come with universal internal current-control drivers, offering constant or strobed operation, reduced wiring requirements, and easy installation. Smart Vision Lights products also are the safest on the market thanks to the company’s in-house IEC 62741 light-testing laboratory, guaranteeing conformity and compliance for your lighting systems, regardless of where they are installed around the globe. Learn more at SmartVisionLights.com.
