Solutions 2.0 Virtual Conference May 17, 2017
Original Release Date: May 17, 2017 - 59:16
How to Balance at a Resonate Frequency
One of the things you run into often when you do field balancing is balancing and having a difficult time doing it, only to discover you’re trying to balance a machine that is at or near its resonate frequency point. This can be done and accomplished successfully, and it’s not particularly hard. There are a number of different ways to accomplish balancing when you have no choice but running the fan in or near resonance. This presentation covers what resonance is, why it effects balancing, and the solutions to the problem.
Learning to See with FRACAS
About 6 or 7 years ago, I discovered that there was a gap in the learning when you went into a traditional maintenance organization with some of the terminologies and things the industry is moving to as far as reliability is concerned. I saw a need to bridge that gap. In this webinar, you will learn how to use FRACAS to train a maintenance workforce new to reliability.
Solutions 2.0 PPT 5-17-17
The Order Hub ECommerce for Maximo
Solutions 2.0 Virtual Conference May 17, 2017 provided by
