by Quinton GoForth, GenesisSolutions
The engine behind a leading edge maintenance and asset management program is the CMMS. Although Maximo functionality has been enhanced with each new version, there are still a number of external analyses required to optimize the system’s use, such as FMEA. The key to optimizing your program is linking the output data from each analysis to the proper Maximo field.
by Rüdiger Krethe, OilDoc Academy
Modern lubricants are machine elements. Without tailor-made lubricants, the effective and reliable operation of modern machines and facilities is impossible! Accurate laboratory instruments produce significant information from even small amounts of oil or grease. But to allow to identify the consequences necessary, it’s important to find the best right analysis scope and to tailor the limit values on modern parameters. As a consequence, future oil analysis programs must be “designed to application.”
