Starter Leak Detection Kit Finds Leaks in Oil-Based Fluid Systems
Spectroline® OPK-441 Industrial Leak Detection Kit is a starter kit designed to pinpoint the exact source of all leaks in hydraulic equipment, compressors, engines, gearboxes and fuel systems.
The kit features the OPTIMAXTM 400 violet light LED flashlight, a compact, high-intensity unit that quickly reveals all leaks in small to medium-sized oil-based fluid systems - even in cramped areas that are inaccessible to larger lamps.
Also included is an 8 oz (237 ml) twin-neck bottle of patented OIL-GLO® 44 concentrated fluorescent oil dye, which is compatible with all synthetic and petroleum-based fluids. When a leaking system is scanned with the OPTIMAX 400 flashlight, the dye glows a bright yellow/green at all leak sources to reveal the precise location of each and every leak.
Rounding out the kit is an 8 oz (237 ml) spray bottle of GLO-AWAYTM dye cleaner, dye treatment tags, and fluorescence-enhancing glasses. All components are packed in a rugged carrying case.
Headquartered in Westbury, New York, Spectronics Corporation invented fluorescent leak detection in 1955, and remains the world’s leading manufacturer of ultraviolet equipment and fluorescent dyes. Spectroline® cutting-edge, top-quality, industry-awarded lamps, dyes, radiometers and diagnostic tools are built to exacting standards, and are used for literally dozens of markets, some of which include Industrial, Air Conditioning & Refrigeration, Laboratory, Semiconductor, Nondestructive Testing and Forensics. Spectronics Corporation is dedicated to upholding high standards in design manufacturing, ensuring customer satisfaction and developing innovative technologies that make the world a better place. For more information, visit the website at www.spectroline.com.
