Starter Leak Detection Kit Ideal for Finding Leaks in Oil-Based Fluid Systems!
The kit features the OPTIMAX JrTM blue light LED flashlight, a compact, high-intensity unit that quickly reveals all leaks in small to medium-sized industrial systems - even in cramped areas that are inaccessible to larger lamps. It measures just 7¼ inches (19 cm) long and weighs only 5 ounces (140 g).
Also included is an 8 oz (237 ml) twin-neck bottle of patented OIL-GLOTM 44 concentrated fluorescent oil dye, which is compatible with all synthetic and petroleum-based fluids. When a leaking system is scanned with the OPTIMAX Jr flashlight, the dye glows a bright yellow/green at all leak sources to reveal the precise location of each and every leak!
Rounding out the kit is an 8 oz (237 ml) spray bottle of GLO-AWAYTM dye cleaner, dye treatment tags, and fluorescence-enhancing glasses. All components are packed in a rugged carrying case.
For more information about the Spectroline® OPK-541 Industrial Leak Detection Kit, call toll-free 1-800-274-8888. Outside the United States and Canada, call 516-333-4840. Website at www.spectroline.com.
