The “Gross to Close” Method to Find Leaks
Finding leaks is easy using the “Gross to Close” method. With headphones on and amplification set to 50-60dB, adjust headphone volume comfortably. Wave the detector back and forth and up and down while listening for the leak. Ultrasound is directional so the source is easy to isolate. Reduce amplification as you close in on the leak. Once the leak source is isolated attach a precision indicator to shield competing ultrasound.
Download LUDECA's Fix-and-Find Leaks Procedure
Tip provided by
