The Connection Between Rcm2 And The Pas-55 Framework
There are many approaches to implementation of the requirements outlined in PAS-55; Reliability-Centered Maintenance (RCM2) is one of the choices available. This web workshop will provide insight into the RCM2 methodology and how it applies to the PAS-55 specification.
1) Parts of the PAS-55 Specification can be achieved through implementation of RCM2
2) RCM2 helps you to understand the causes of failure in your equipment (failure modes)
3) If applied correctly, RCM2 results in a technically valid, optimized maintenance program.
