Turn Any Android or Windows Device into a Powerful Condition Monitoring Data Collector
November 2016
Machine Sentry® integrates all condition monitoring techniques and watchkeeping data into a Condition Based Maintenance (CBM) solution to provide effective maintenance planning and reporting. Machine Sentry®is simple to use, and includes automatic fault diagnosis assistant that helps identify potential issues with rotating equipment.
The use of readily available hardware coupled with the unique Bluetooth™ enabled tri-axis vibration sensor (Pat. Pending) significantly reducing the cost of the equipment required for data collection. The integrated fault diagnosis assistant, automatically detects rotating equipment problems (broadly equivalent to a level II vibration analyst) simplifies data analysis. The algorithms used in the Fault Diagnosis Assistant have been developed by AVT Reliability’s own team of vibration experts using thousands of hours of vibration data coupled with extensive field experience
Machine Sentry® combined with access to AVT’s team of condition monitoring experts eliminates the requirements and costs associated with hiring highly qualified condition monitoring engineers and technicians making it the ideal solution to any condition monitoring program
For more information visit: www.machinesentry.com.
