Use Data to Determine When to Use Permanent or Portable Filtration
Video Tutorial -
By Jason Kopschinsky, Director of Reliability Services- Des-Case Corporation
In many plants the most expensive assets generally get the most attention, but many critical assets are not necessarily the most expensive. This philosophy is often used when deciding when to use offline filtration and when that offline filtration should be permanent or portable. This iPresentation walks you through a maze of data to uncover the clues behind when filtration should be permanent versus portable.
Learning Points:
  • Use oil analysis to drive the decision making process
  • The more data available the easier the decisions will be
  • Root causes should be addressed first
