Violet Light LED Leak Detection Flashlight Makes All Industrial Fluid Leaks Glow Brightly!
The OPTIMAX 400 features a high-output LED that causes fluorescent dyes to glow more brilliantly and with greater contrast than conventional lamps. The flashlight’s pre-focused beam optimizes fluorescent response without any adjustments needed. With power comparable to high-intensity 150-watt lamps, it works well with Spectroline® OIL-GLO® 33 (green), OIL-GLO® 44 (yellow/green) and OIL-GLO® 50 (red) oil-based dyes, as well as WATER-GLO® 802 (green) water dye.
The OPTIMAX 400 is engineered with “instant-on” operation. Its cordless, compact design allows it to get into tight, cramped areas larger lamps can’t. A rugged, corrosion-resistant, anodized lamp body stands up to years of heavy use. Powered by standard AAA batteries (included), this unit features an LED with a 100,000-hour service life.
The flashlight comes with a lanyard, belt holster and fluorescence-enhancing glasses, all packaged in a full-color hanging clamshell.
For more information, call toll-free 1-800-274-8888. Outside the U.S. and Canada, call 516-333-4840. Website at www.spectroline.com.
