Wind Turbine Balancing with VIBXPERT
Wind turbines turn at very slow rotational speeds, a challenge to balance. The VIBXPERT will help overcome these challenges improving the balance conditions and result in a significant increase in the uptime and availability. With its new built-in wind balancing program, software, accelerometers linear to 0.1 Hz, speed sensor and balance grade tolerance chart (G16), it is the ideal portable system for mass unbalance of wind turbine rotor blades.
More details online at http://www.ludeca.com/prod_vibxpert_balancing.php
Keep the blades turning with LUDECA Wind.
About LUDECA
LUDECA is a vendor of Preventive, Predictive and Corrective Maintenance Tools including laser alignment, vibration analysis and balancing as well as software, services and training. For more information, visit www.ludeca.com
