From Data to Decisions: Leveraging AI to Improve Turbomachinery & Data Reliability
Reliability organizations today are not short of data—they are short of clarity. Modern gas turbines and rotating equipment generate vast amounts of operational data, yet translating that data into timely, confident decisions remains a persistent challenge. Engineers are often faced with multiple interacting variables, conflicting signals, and limited time to diagnose emerging issues. Artificial intelligence (AI) and machine learning (ML) offer a way to bridge this gap—not by replacing engineering judgment, but by accelerating it. When applied correctly, these tools help identify the variables that truly matter, reduce diagnostic uncertainty, and focus attention on the factors most likely to influence performance and reliability. The result is not only improved asset outcomes, but also a measurable improvement in how engineering time is utilized—effectively linking return on investment (ROI) with what can be considered a return on engineering effort.
To illustrate this approach, two LM6000 aero derivative gas turbines operating at different plant locations were analyzed. While both units are similar in design, their operating conditions and performance characteristics exhibited noticeable variation. The objective was not simply to compare performance, but to determine which variables were most influential in driving differences in behavior and reliability outcomes. A set of key operating parameters was evaluated, including power output, inlet conditions, fuel characteristics, compressor and turbine variables, and environmental factors. These included turbine power, inlet temperature, fuel flow, compressor discharge pressure, variable geometry positions (such as variable bleed valves and inlet guide vanes), pressure drops across filtration systems, humidity, and rotor speed, among others. While this study focused on a defined group of variables, the broader principle remains: effective analysis depends not on the quantity of data, but on identifying the subset of variables that meaningfully influence system behavior. The LM6000 platform provides a useful context for this type of analysis due to its complexity and its aero derivative heritage. Derived from the CF6-80C2 aircraft engine, the LM6000 incorporates a free power turbine configuration, where the gas generator and power turbine are mechanically decoupled. This distinction is important from a reliability and analytical perspective. Unlike aerodynamically coupled systems, changes in load do not directly shift the compressor operating point through the gas path, allowing certain aspects of compressor behavior to be analyzed with greater independence. This structural characteristic enables a more focused evaluation of performance drivers without immediate interference from load variations, aside from secondary effects such as exhaust backpressure. From a reliability standpoint, this provides an opportunity to isolate cause-and-effect relationships more effectively when applying advanced analytics.
It is important to emphasize that the objective of this work is not to replace fundamental engineering understanding of the LM6000 or similar machines. Rather, it is to demonstrate how AI and data-driven methods can be integrated with domain expertise to reduce the time required to interpret complex datasets, identify emerging deviations, and converge more quickly on the variables that matter most. In doing so, reliability teams can move from broad data exploration toward targeted, actionable insights.
A general overview of the LM6000 configuration is shown in Figure 1, providing context for the system architecture discussed in this analysis.
Figure 1: General overview of a LM6000 Gas Turbine Engine.
The LM6000 gas turbine represents a class of highly engineered, aero derivative machines designed for efficiency and operational flexibility. Derived from the CF6-80C2 high-bypass turbofan aircraft engine—widely used on platforms such as the Boeing 767, Boeing 747-400, and Airbus A300—the LM6000 brings aviation-grade design into industrial power applications. One of the most important characteristics of this platform, from both a reliability and analytical standpoint, is its free power turbine configuration. In this arrangement, the gas generator and power turbine are mechanically decoupled, meaning that load changes are not directly transmitted through the gas path to the compressor. This differs from aerodynamically coupled systems, where load variations can immediately influence compressor operating conditions and surge margin.
For reliability engineers and leaders, this distinction is more than a design detail—it shapes how the machine should be analyzed. Because the compressor is not directly load-driven, its behavior can be assessed with a greater degree of independence. While secondary effects such as exhaust backpressure may still play a role, the primary operating point of the compressor is not immediately dictated by generator load changes. This separation provides a practical advantage when applying data-driven methods. It allows analysts to evaluate performance drivers and emerging deviations without the same level of confounding influence from load variability. In turn, this supports more targeted diagnostics and clearer identification of cause-and-effect relationships within the system. The intent is not to replace foundational engineering understanding of the LM6000 or similar turbomachinery. Rather, it is to demonstrate how machine learning and advanced analytics—when combined with domain expertise—can significantly reduce the time required to interpret complex datasets and focus attention on the variables most likely to influence reliability outcomes.
A Decision-Focused Analytics Framework for Reliability
From a reliability leadership perspective, the objective of applying machine learning is not to build complex models—it is to improve the speed and quality of decisions. The approach used in this study was structured around that principle: identifying which variables truly influence outcomes, and doing so in a way that reduces ambiguity in troubleshooting complex equipment. The analysis began by clearly defining the problem in operational terms. Instead of analyzing data broadly, two specific conditions were targeted: power fluctuations and trip events. By anchoring the analysis to real operational outcomes, the focus remained on decisions that matter to plant performance rather than on abstract data exploration. A structured screening process was then applied to narrow down the variables that influence these outcomes. Initial assessment included identifying linear relationships between variables, followed by evaluating directional influence using information-based methods capable of capturing non-linear interactions. This step is critical in complex systems, where traditional correlation alone can mislead decision-making by failing to distinguish between coincidence and influence. Once potential drivers were identified, the analysis shifted toward understanding what happens immediately before an event occurs. Rather than examining steady-state data, variables were evaluated within defined time windows leading up to trips or fluctuations. This pre-event perspective allows reliability teams to move from reactive analysis toward early detection of emerging conditions. From a leadership standpoint, this is where analytics begins to add value: it transforms large datasets into focused signals that indicate where attention should be directed.
To further refine the analysis, machine learning classification techniques were used to distinguish between normal operation and pre-event conditions. These models rank variables based on their relative importance, helping to identify which factors consistently contribute to undesirable outcomes. Explain ability techniques were also applied to ensure that results could be interpreted and trusted by engineering teams, rather than treated as “black box” outputs. An important consideration in this process is avoiding false confidence. In practice, models can inadvertently “learn” from variables that directly define an event—for example, using rotor speed to predict a trip event defined by a drop in speed. This creates artificially high accuracy without delivering real insight. To address this, variables that directly encode the outcome were intentionally excluded from predictive models. This step is essential to ensure that results reflect true drivers rather than mathematical shortcuts. Another key element of the approach was the identification of operating regimes. Complex machines do not behave uniformly across all conditions, and anomalies often emerge only within specific operating envelopes. By grouping data into representative regimes, it becomes possible to determine whether certain events are tied to particular modes of operation. For reliability leaders, this provides a more actionable understanding of risk—highlighting not just what is happening, but when and under what conditions it is most likely to occur.
Finally, the analysis was structured to visualize how key variables evolve leading up to an event. This enables teams to see not just which variables matter, but how they behave over time prior to failure or instability. Such insights support earlier intervention and more targeted investigation. It is important to recognize that no single analytical method provides all the answers. Correlation-based approaches help identify relationships, while information-based methods provide insight into directional influence. Used together, they form a more complete picture of system behavior. However, these tools must always be interpreted within the context of engineering knowledge to avoid misinterpretation. Ultimately, the value of this framework lies not in the algorithms themselves, but in how they are used. By structuring analysis around decision-relevant outcomes, focusing on pre-event behavior, and ensuring interpretability, reliability teams can move from broad data analysis to clear, actionable insight—reducing time to diagnosis and improving confidence in corrective actions.
Initial screening of relationships between variables was conducted using correlation analysis. While correlation does not establish causality, it provides a useful baseline for identifying potential associations across variables in each unit. A comparison of these relationships for both turbines is presented in Figure 2.
Figure 2: Turbine 1A correlation map (left) and Turbine 1B correlation map (right)
Figure 3: Data comparison between Turbine 1A (left) and Turbine 1B(right).
Figure 3 highlights a comparison of key operating relationships between the two turbines (1A and 1B), with a particular focus on how different variables influence power output. Rather than relying solely on correlation—which identifies relationships but not direction—the analysis evaluated how changes in one variable influence another over time. This distinction is important in complex systems, where apparent relationships may not reflect true drivers of performance.
The results indicate that, for Turbine 1A, the Variable Inlet Guide Vane (VIGV) position exerts a stronger influence on power behavior relative to Turbine 1B under the conditions studied. From a reliability standpoint, this is a meaningful insight. It suggests that VIGV operation is more tightly coupled to performance variability in one unit than the other, highlighting a potential area for focused investigation. For reliability teams, this type of insight helps move beyond general observation toward targeted action. Instead of broadly reviewing multiple variables, attention can be directed toward specific control elements that have a demonstrable impact on performance. In this case, differences in VIGV behavior may warrant further evaluation of control tuning, mechanical condition, or response characteristics between the two units. More broadly, the value of this analysis lies in its ability to distinguish between variables that are merely associated with an outcome and those that actively influence it. This enables more confident prioritization of engineering effort, reducing time spent on low-impact factors and accelerating convergence toward root cause.
A critical component of effective reliability analysis is understanding how equipment behaves across different operating conditions. Complex systems such as gas turbines transition across multiple regimes depending on load, ambient conditions, and control responses. The identified operating regimes for both turbines are illustrated in Figure 4, enabling clearer differentiation between normal operation and conditions where anomalies are more likely to occur.
Figure 4: Operating Regimes for the Two Turbines
A critical component of effective reliability analysis is understanding how equipment behaves across different operating conditions. Complex systems such as gas turbines do not operate in a single steady state; rather, they transition across multiple regimes depending on load, ambient conditions, and control responses. Segmenting data into these operating regimes enables a clearer distinction between normal behavior and conditions under which anomalies—such as trips or emissions excursions—are more likely to occur. For example, elevated NOx emissions may only arise under specific operating scenarios. Framing this as a classification problem—rather than attempting to predict exact values—can provide a more practical understanding of when and why these conditions emerge. From a reliability leadership perspective, this shift is important: the objective is not always precise prediction, but reliable identification of risk conditions that require action.
In practice, applying machine learning to high-dimensional systems presents its own challenges. Models trained on large numbers of variables may underperform, not due to limitations in the algorithms themselves, but because of issues such as feature overlap, data leakage, or misalignment between the model structure and the physical system. Without careful design, models can appear accurate while failing to provide meaningful insight.
This reinforces an important principle: The effectiveness of analytics is determined more by problem definition and feature selection than by algorithm choice.
When properly structured, however, machine learning models can provide significant value. By identifying and ranking the variables most associated with undesirable outcomes—such as trips or power fluctuations—they help direct engineering attention toward the factors that matter most. In this study, the variables highlighted by the models aligned with independent findings from the OEM, which identified concerns related to variable bleed valve (VBV) behavior. This type of alignment between data-driven insight and domain expertise is critical. It builds confidence in the analytical approach and ensures that results can be translated into practical actions, such as targeted inspections, control system evaluations, or component-level assessments. Beyond identifying key drivers, additional analysis—such as sensitivity or elasticity assessments—can further quantify how changes in one variable influence another. This provides a deeper understanding of system responsiveness and supports more informed decision-making when evaluating operating adjustments or maintenance strategies. From a business perspective, the implications are significant. Performance degradation or operational constraints in complex equipment can translate directly into financial loss. For example, a sustained reduction in power output—even by a single megawatt—can result in substantial revenue impact over time, depending on market conditions. More importantly, delayed diagnosis of underlying issues can amplify these losses and increase operational risk. This is where reliability leadership plays a defining role. Effective leaders must be able to bridge technical understanding with timely decision-making—ensuring that emerging issues are identified, prioritized, and addressed before they escalate. Machine learning and data-driven methods provide a powerful complement to this process by reducing uncertainty and accelerating convergence toward root cause. However, these tools must be applied with discipline. Incorrect assumptions, poorly selected features, or inadequate model validation can lead to misleading conclusions and wasted effort. Analytics should not be viewed as a substitute for engineering judgment, but as an extension of it—enhancing the ability to interpret complex systems rather than replacing foundational knowledge.
Ultimately, the value of integrating AI and machine learning into reliability practices lies in their ability to transform large volumes of data into focused, actionable insight. When combined with domain expertise, these tools enable organizations to respond more quickly, allocate resources more effectively, and make more confident decisions in the face of complexity.
To further focus engineering attention, machine learning models were used to rank variables based on their contribution to specific outcomes. The key drivers associated with trip events and power fluctuations are summarized in Figures 5 and 6, respectively. These results highlight a relatively small subset of variables that consistently influence system behavior.
Figure 5: Feature importance showing higher contributing features leading to Tripping between the two turbines
Figure 6 : Feature importance showing higher contributing features leading to Power fluctuations between the turbines
Notably, the variables identified through the analysis aligned with independent OEM findings, which highlighted concerns related to variable bleed valve (VBV) behavior. Supporting trends from the control system are illustrated in Figure 7.
Fig 7: VBV concerns noticed on trending VBV data within the GE control system DCS.
A consolidated comparison of the contributing features across both turbines is presented in Figure 8, providing a high-level view of how key drivers differ between units.
Figure 8: Summarization of the output from two Turbines showing different features that are contributing to power fluctuations on the different units.
References:
