Closed Loop Asset Performance Management Turning Insights into Reliability Outcomes
Asset-intensive organizations continue to be under increasing pressure to improve reliability, reduce operating costs, extend asset life, and make better use of capital. Utilities are modernizing grids, oil and gas companies are managing large, geographically spread assets while dealing with ageing infrastructure and ongoing geopolitical tensions, manufacturers are protecting production capacity, and data centers are becoming a critical asset class requiring high availability. In response, organizations have invested over time in EAM, GIS, SCADA, historians, sensors, mobility, analytics, and digital platforms.
Many organizations have also introduced Asset Performance Management (APM) solutions to improve asset health visibility and enable predictive maintenance. However, business outcomes have not always improved in the same proportion. Organizations still struggle with reactive maintenance, incomplete asset data, inadequate failure history, and low trust in predictive models. The issue is not always lack of technology. More often, the issue is that asset information, failure history, risk models, maintenance plans, and field execution are not digitally connected in a way that helps maintenance planners make timely decisions.
The next phase of APM must therefore focus less on standalone insights and more on connected action. This requires a practical path that connects value realization, asset ontology, trusted asset information, closed-loop decisioning, and sustained reliability operations. APM must become a closed-loop reliability discipline where asset condition, failure probability, criticality, risk, recommended action, work execution, and field feedback operate as one connected system. The shift is from merely “knowing something may fail” to consistently “taking the right action at the right time and using the result to improve future decisions.”
The Changing Asset Landscape
Asset intensive industries are operating in a more complex and demanding environment. Reliability is no longer only a maintenance concern. It has become a management priority as asset failures can affect production, safety, customer service, regulatory compliance, and brand trust.
At the same time, the asset base is becoming more complex. Assets are now connected with sensors, control systems, enterprise applications, and field mobility tools that generate large volumes of operational, maintenance and inspection data. New asset classes are also being added, especially in energy transition, renewables, distributed infrastructure, and automated operations. This makes the operating environment more data-rich, but not necessarily more decision-ready.
As the asset data grows, organizations need a stronger foundation to make this data useful for reliability decisions. Predictive models, analytics platforms and digital twins can create value only when they are built on accurate asset information and connected to how maintenance and reliability decisions are planned, executed, and improved.
Why Traditional APM Programs Underperform
Many APM initiatives start with the right intent but become technology heavy during execution. Organizations implement dashboards, connect sensor feeds, configure analytics models, and generate alerts. This improves visibility, but visibility alone does not improve reliability.
The real challenge begins after an alert is generated. Maintenance teams need to understand what the alert means, whether the risk is real, what action is required, when the action should be taken, and whether the action has actually reduced the risk. If this chain is broken, APM remains a monitoring exercise rather than a reliability improvement program.
This is why many predictive maintenance pilots remain as pilots. They show technical feasibility but fail to become part of day-to-day maintenance planning. Alerts may not be explainable, and asset history may be weak. Sometimes models are built without enough reliability input. Recommendations may not flow into EAM and field service systems. As a result, the organization gets another dashboard, but not a new way of working.
The starting point for APM should therefore be the quality, structure, and usability of asset data, not model development or dashboard design.
The Foundation: Reliable Asset Information
Closed-loop APM starts with asset data; not in a narrow IT sense, but as information that is fit for reliability and maintenance decisions.
Most organizations already have large amounts of asset data, but it is often spread across EAM, historians, GIS, inspection systems, spreadsheets, OEM systems, and field applications. Asset hierarchy may not be consistent. Failure codes may not be used properly. Sensor tags may not be mapped to the right equipment. Inspection observations may be stored as free text. In such cases, even advanced analytics will struggle.
A strong asset information foundation brings together asset hierarchy, equipment attributes, operating context, inspection history, work history, failure modes, condition data, asset criticality, and consequence information. It also requires a common data structure across enterprise, operational, and field systems so that asset condition, maintenance history, and reliability context can be viewed together.
For many organizations, this requires an asset ontology: a common structure that defines how assets, components, locations, attributes, failure modes, condition indicators, risks, and maintenance actions relate to each other. This structure helps connect information across EAM, historians, inspection systems, sensors, engineering records, and field applications. It also provides the context needed for health scoring, risk ranking, predictive models, and maintenance decision-making.
This is where ISO 55000 principles, ISO 55001 aligned asset management practices, and reliability methods such as FMEA and FMECA become important. They help organizations move from fragmented asset records to a more reliable basis for health scoring, risk ranking, and maintenance decision-making.
This foundation may not attract the same attention as AI models or digital twins, but it is often the difference between a successful APM program and another reporting layer. Without reliable asset data, APM remains limited to alerts and dashboards. With reliable data, APM can become a decision-making capability that supports risk-based maintenance, better capital planning, and continuous reliability improvement.
From Prediction to Closed-Loop Decisioning
Predictive maintenance answers an important question: what is likely to fail? But for business outcomes, that question alone is not enough. Maintenance teams also need to understand why the failure is likely, how critical the asset is, what action is required, and whether that action has reduced risk.
Closed-loop APM addresses this gap by connecting insight, decision, execution, and learning into one continuous reliability cycle. It brings together asset condition, reliability models, health scores, criticality, risk logic, recommended actions, work execution, and field feedback. The objective is not only to predict failure, but to create a decision flow where asset insights consistently influence how maintenance is planned, prioritized, executed, and improved.
The feedback loop is what makes this model sustainable. When work results, technician observations, replaced parts, and failure confirmations are captured and fed back into the model, APM moves from prediction to connected intelligence. Insights are converted into action, model confidence improves, planner trust increases, and future decisions become stronger.
The closed loop turns APM from a prediction too into a continuous improvement capability. Each completed action adds learning back into the system, helping improve model confidence, planner trust, maintenance decisions, and asset performance over time.
The Target State: APM as an Operating Capability
The target state for APM should not be described only as a platform architecture. It should be described as a new operating capability.
In a mature closed-loop APM model, asset data is governed, reliability models are owned, health and risk scores are trusted, predictive alerts are explainable, recommendations are linked to business consequences, and maintenance actions are executed. Field feedback is not treated as an afterthought. It becomes an important input for improving future decisions, reliability models, and maintenance strategies.
This also changes how maintenance is planned. Critical assets receive more focused attention. Low-risk work can be safely deferred or optimized. Maintenance spend can be better justified. Capital replacement decisions can be supported by health, risk, and consequence data.
In this model, APM becomes part of how the organization plans reliability, manages risk, prioritizes work, and improves asset performance over time.
Building the Business Case
The business case for APM should not be built around the number of sensors, dashboards, models, or integrations. Those are enablers. The business case should be built around measurable operational and financial outcomes, with value realization defined from the beginning. A practical baseline should cover downtime, emergency work percentage, maintenance cost, repeat failures, asset availability, and risk exposure. Without this baseline, benefits remain difficult to prove and the program may be seen as another technology investment.
The strongest value normally comes from reducing unplanned downtime, improving asset availability, reducing emergency maintenance, optimizing preventive maintenance workload, and extending asset life. In regulated or safety-critical environments, improved compliance, audit readiness, and risk visibility are equally important.
Early proof of value is critical. Large multi-year programs are difficult to justify unless the organization can show visible improvement quickly. A practical APM journey should therefore start with one or two high-value asset classes, and a measurable outcome within 8-12 weeks.
A Practical Roadmap for Adoption
A closed-loop APM journey should be phased, and it does not need to start as a large transformation program. It should start with an advisory led value realization exercise to establish the reliability baseline, identify high-risk asset classes, prioritize use cases, and define measurable outcomes.
The next priority is to strengthen the asset ontology and information foundation so that asset hierarchy, failure modes, condition indicators, work history, criticality, risk, and recommended actions are connected in a usable structure.
A focused MVP for one critical asset class can then be used to prove the closed-loop approach: identify a risk, generate a recommendation, create or influence a work order, complete the action, capture feedback, and measure benefit against the baseline.
As the capability matures, the program should move from implementation to managed outcomes through model governance, reliability reviews, data quality monitoring, benefit tracking, and continuous improvement.
The Role of AI and Digital Twins
AI and digital twins can play an important role in closed-loop APM, but their value depends on how well they are connected to reliability context and maintenance execution. AI can detect patterns across operating data, work history, inspection records, and condition signals. Digital twins can help simulate asset behavior, test operating scenarios, and understand how changes in load, environment, or maintenance strategy may affect performance.
However, these technologies should not be treated as standalone intelligence layers. A prediction has limited value if it is not explainable, linked to asset criticality, converted into a recommended action, and connected to work execution. Similarly, a digital twin creates real value only when it is supported by trusted asset information and used to improve maintenance, reliability, and capital decisions.
Human expertise must remain central to the decision process. Reliability engineers, maintenance planners, and field teams should validate model outputs, challenge recommendations where needed, and feed practical experience back into the system. This human-in-the-loop approach improves trust, reduces blind reliance on algorithms, and ensures that AI-supported decisions remain grounded in operational reality.
The most effective APM programs will combine engineering models, statistical methods, AI/ML, digital twins, field knowledge, and enterprise workflow integration. The objective is not just to generate better insights, but to help maintenance teams make reliability decisions faster, more consistently, and with greater confidence.
Asset Performance Management is entering a new phase. The earlier phases were largely about monitoring assets and predicting failures. The next phase is about closing the loop between insight and action.
For asset-intensive organizations, the opportunity is significant. A well-designed APM program can reduce unplanned downtime, improve productivity, extend asset life, and strengthen safety and compliance. But this value will not come from technology alone. It will come from connecting asset data, reliability models, risk-based decisions, work execution, and continuous learning.
Closed-loop APM is therefore not just the future of predictive maintenance. It is the practical path to more reliable, resilient, and value-driven asset operations.
The real test of APM maturity is not whether an organization can predict failures. It is whether asset insights consistently change how maintenance is planned, executed, measured, and improved. That is where closed-loop APM creates lasting value.
Praveen Kumar Agrawal
Praveen Agrawal is an Asset Management expert with over 30 years of global experience across energy, utilities, and manufacturing industries. He has led large-scale business transformation programs and brings deep expertise in practice building, business planning, consulting, solution design, and technology implementation. He has worked with leading organizations globally, and is recognized for his thought leadership through active contributions to industry forums and collaboration with global analysts. Praveen’s experience spans both software product and services organizations, where he has also helped establish Professional Services teams. He also served as an Independent Director at Mechartes, an engineering firm focused on advanced consultancy for asset-intensive industries. He also has an early academic foundation in Artificial Intelligence and Natural Language Processing.
