Beyond the CMMS: Why Maintenance Compliance Alone Cannot Guarantee Asset Reliability
Introduction
In asset-intensive industries such as oil and gas, petrochemicals, and energy services, equipment reliability directly influences operational safety, production performance, and lifecycle costs. Computerized Maintenance Management Systems (CMMS) have long served as the backbone of maintenance operations, managing asset hierarchies, preventive maintenance schedules, work orders, and spare parts records.
Because of this central role, many organizations rely heavily on preventive maintenance (PM) compliance metrics as an indicator of maintenance performance. High compliance rates often create the perception that assets are being properly maintained and should therefore operate reliably.
However, field experience across industrial operations frequently reveals a gap between maintenance execution metrics and actual asset reliability. Equipment with high PM compliance can still experience unexpected failures due to operational stresses, degradation mechanisms, or subsystem anomalies that remain invisible within maintenance records.
This limitation arises because CMMS platforms were designed primarily to manage maintenance transactions, not to perform integrated reliability analytics. Addressing this gap requires combining maintenance data with operational intelligence through broader Asset Performance Management (APM) frameworks.
The Limits of Maintenance-Centric Reliability Management
Preventive maintenance compliance measures how consistently scheduled maintenance tasks are executed. High compliance indicates strong maintenance discipline and effective planning.
Yet PM compliance measures process adherence, not equipment condition.
For example, a centrifugal pump may show full maintenance compliance while still experiencing degradation caused by:
  • hydraulic instability or cavitation
  • increased process load or system head
  • progressive bearing wear
  • abnormal temperature conditions affecting seals
These degradation mechanisms may develop gradually during operation and remain undetected within maintenance records until a failure occurs.
As a result, organizations that rely solely on maintenance compliance metrics may develop a false sense of reliability assurance. True reliability assessment requires combining maintenance execution data with operational performance indicators.
Maintenance Data as a Reliability Baseline
CMMS data remains an essential foundation for reliability analysis. Maintenance history provides insight into equipment behavior over time and supports several important reliability metrics.
PM compliance reflects the consistency of maintenance execution. Work order history and failure reports allow reliability engineers to identify recurring failure modes and evaluate trends such as increasing repair frequency or declining mean time between failures (MTBF).
Statistical tools such as Weibull analysis or failure distribution modeling can be applied to understand whether equipment failures are random, early-life related, or wear-out driven.
Maintenance history also supports Remaining Useful Life (RUL) estimation. RUL models combine failure distributions with operational stress indicators to estimate how long equipment can continue operating before reaching unacceptable failure risk. These models enable predictive maintenance strategies that intervene before assets enter high-risk degradation stages.
Operational Intelligence: The Missing Dimension
Operational systems generate continuous telemetry describing how equipment behaves in real time. These signals often reveal early degradation long before failures appear in maintenance records.
Examples of operational indicators include:
  • vibration signatures in rotating equipment
  • pressure and flow stability in fluid systems
  • temperature patterns across components
  • motor current signatures indicating load variation
Abnormal trends in these indicators often precede mechanical failure.
Practical Example: Pump Reliability in Field Operations
Consider a high-pressure pump operating in an oil and gas fleet. The CMMS may show that all preventive maintenance tasks—such as lubrication, inspections, and seal replacements—have been completed according to schedule, resulting in nearly 100% PM compliance.
From a maintenance execution perspective, the asset appears healthy. However, operational monitoring may reveal early warning indicators such as gradually increasing vibration amplitude, minor pressure instability, or rising bearing temperature. These signals may indicate progressive bearing wear or hydraulic imbalance developing within the pump.
Because these degradation signals originate from operational behavior rather than maintenance activities, they may not appear in the CMMS until the equipment eventually fails and a corrective work order is generated.
By integrating operational telemetry with maintenance records through an APM framework, reliability teams can detect these patterns early, investigate root causes, and schedule targeted interventions before a failure event occurs.
Building an Integrated Asset Performance Management Framework
Modern Asset Performance Management architecture extends the CMMS by integrating multiple sources of operational and maintenance data.
Typical inputs include:
  • CMMS maintenance history
  • SCADA or control system telemetry
  • IoT sensor data
  • Inspection and condition monitoring records
  • Engineering Reliability Models
Analytical models within APM environments evaluate asset condition using techniques such as anomaly detection, degradation trend analysis, and failure probability modeling.
The outputs may include:
  • Asset health indices
  • Degradation trend indicators
  • Predicted failure timelines
  • Risk-based maintenance recommendations
Rather than replacing the CMMS, APM systems act as a reliability intelligence layer that enhances maintenance decision-making.
From Maintenance Execution to Reliability Intelligence
Integrating operational and maintenance data shifts the focus of maintenance organizations.
Traditional programs emphasize execution metrics such as PM compliance and work order completion. While important, these metrics do not fully represent equipment health.
Integrated reliability analytics allow organizations to evaluate questions such as:
  • Which assets show early degradation patterns?
  • Which equipment is operating under abnormal stress conditions?
  • Where are failure probabilities increasing?
Maintenance can then be prioritized based on risk and equipment condition rather than purely calendar-based schedules.
Implications for Asset Lifecycle Management
Combining maintenance history with operational behavior also improves long-term asset planning. Integrated analytics help organizations identify equipment fleets experiencing accelerated degradation and determine whether assets should be refurbished, redesigned, or replaced.
Lifecycle decisions based on empirical reliability data allow organizations to optimize capital investments and extend asset life where appropriate.
Preventive maintenance compliance remains an important indicator of maintenance discipline, but it does not guarantee asset reliability. Equipment health is influenced by operational conditions, degradation patterns, and instrumentation performance that may not be visible within maintenance systems alone.
By integrating maintenance records with operational intelligence through Asset Performance Management frameworks, organizations gain a more accurate understanding of asset health. This integrated approach enables earlier detection of degradation, improved maintenance prioritization, and better lifecycle decision-making.
As industrial operations continue to become more connected and data-driven, reliability management must evolve beyond maintenance compliance metrics toward holistic, data-integrated asset performance evaluation.
Rajaram Madhavan
Rajaram Madhavan is a Maintenance Business Systems and Digital Asset Management professional in the oil and gas services sector, with over 18 years of experience, specializing in enterprise asset management systems, reliability analytics, and Asset Performance Management. He has led several initiatives involving CMMS platforms, maintenance data analytics, and operational data integration to improve equipment reliability and asset lifecycle performance. His work focuses on integrating maintenance data, operational telemetry, and analytics frameworks to support predictive maintenance and reliability engineering practices. Rajaram holds a master’s degree in mechanical engineering from the Georgia Institute of Technology, USA
