A condition-monitoring alert does not repair a machine. It gives a maintenance team a reason to look. The useful question is what the team does in the next hour, shift, and planned outage.
Start by checking whether the signal is real. Confirm that the sensor is reporting normally and has not been moved or disturbed. Compare the measurement with recent readings from the same machine under similar operating conditions. A motor running at a different speed or load may produce a different vibration reading without developing a fault. If the alert disappears when the process returns to its usual state, record that finding rather than silently dismissing it.
If the change persists, put the evidence beside the machine's history. What was repaired recently? Has the operator heard a new sound or noticed a change in pressure, temperature, flow, or product quality? Has the machine been starting more often? A single reading rarely answers these questions. The history narrows the possibilities and helps the team choose an inspection.
Give the finding to a named owner. That person should know what changed, when it changed, where the measurement was taken, and how the machine was operating at the time. “Check pump P-12” is less useful than “Vibration at P-12 increased over three production shifts at similar speed; verify the sensor mount and inspect the drive-end bearing at the next safe opportunity.” The second note is still a hypothesis. It does not pretend to diagnose a bearing from a trend alone.
The owner then chooses a response proportional to the evidence and consequence of failure. A modest, stable change on a redundant pump might justify an inspection during the next planned stop. A rapidly rising change on a bottleneck asset may call for a prompt field check and a discussion with operations about switching equipment or preparing a controlled shutdown. Safety procedures, operating constraints, and the team's judgment govern that decision. Monitoring data should inform it, not override it.
Record the action and what the technician found. If the machine was inspected, note whether the suspected problem was present, whether another cause was found, or whether the condition was normal for that operating state. If parts were changed, record the actual defect and the condition after repair. That feedback matters because an alert rule tuned only on past alarms can keep repeating the same mistake. A record tied to work orders or another maintenance log also lets the team learn which alerts led to useful action.
Finally, review the alert itself. Was the threshold sensible for this machine and operating mode? Did the team get enough context to act? Was the alert early enough to schedule work, or did the condition develop too quickly? Those questions are more valuable than counting alerts or claiming every detected change was a prevented failure.
The aim is a repeatable path from measurement to inspection to decision. When that path is clear, monitoring becomes part of maintenance work rather than another screen someone must watch.
