CMMS Data Group Announces Plug & Play Lube Storage Rooms with CMMS Integration
Properly storing lubricants, and lube equipment, can greatly extend their life and effectiveness. However, finding an area in the plant that is isolated, free of contamination, and temperature- and humidity-controlled can be extremely difficult. If such a project is undertaken, it is either cost-prohibitive or impossible to even find the space within the facility.
The Solution
Plug & Play Lube Storage Rooms offer a mobile lube storage room delivered to your plant. Select a space in your plant, inside or outside, supply the power, and presto, you have a state-of-the-art lube storage room. The rooms are insulated, climate-controlled, heated, air conditioned, and even de-humidified in some geographic areas.
CMMS Users
Integrate lube consumption directly to MVP Plant & MP2.
Contact us today for more information!
CMMS Data Group
25 E. Washington Street, Suite 1465
Chicago, Illinois 60602 U.S.A.
P: (312) 957-8580
E: info@CMMSDataGroup.com
W: www.CMMSDataGroup.com
