Hard To Reach Fastening Tip
When needing to hold a small screw or bolt to a driver, a small dab of high viscous grease can do the trick to hold it to the screwdriver or in the socket driver and allow you to reach it back into a small location or back to a distant hole in the panel.
Reader tip submitted by Brian Lee Watson, TPM-Spares Coordinator, USSynthetic Corp.
Thanks for the reader Tip Brian. We have made a $10 donation to the Harry Chapin Food Bank on your behalf as a thank you.
Generate your own donation to the Harry Chapin Food Bank by sending in your Maintenance Tip here
