Meggitt Sensing Systems Introduces High-Temperature Output Accelerometer
With its small package, the model 2280 is ideally suited for vibration measurements across three orthogonal axes on aircraft engines, aerospace components, ground-based turbine engines, power plant equipment and other machinery that operates at high temperatures.
The Endevco model 2280 shares the same piezoelectric charge sensor system as the companys popular single-axis 2248 family with 15 years of field-proven performance. Offered with a sensitivity of 3 pC/g, the model 2280 features Meggitts proprietary piezoelectric elements and patented Isobase construction, to provide mechanical isolation of the sensing assembly from the mounting surface and minimize base strain.
The accelerometer is 1.35 inch (35mm) square and weighs less than 0.6 pounds (270 grams). It has three 10-32 side connectors and is mounted with two 8-32 bolts. The unit is hermetically sealed, and signal ground is isolated from the outer case of the unit. Three 10-foot Endevco model 3075M6-120 high-temperature, low-noise cables are supplied with the unit for error-free operation along with two mounting screws. Recommended optional accessories include the Endevco model 2721B charge amplifier and 2771C remote charge converter. The sensor is fully compliant with the European Union Low Voltage Directive 2006/95/#C and EMC Directive 2004/108/EC and bears the CE mark.
All sensing elements are manufactured in-house at Meggitts ISO9001-certified MEMS facility in Sunnyvale, California, USA. In addition, the Endevco model 2280 is covered by a five-year comprehensive product warranty.
For more information on the Endevco product line, visit www.endevco.com. For full details on all Meggitt Sensing Systems products, visit www.meggittsensingsystems.com.
About Meggitt Sensing Systems
Meggitt Sensing Systems, a Meggitt group division (www.meggitt.com), is a leading supplier of high-performance sensing and monitoring systems for physical parameter measurements in extreme environments. It has operated since 1927 through its antecedents - ECET, Endevco, Ferroperm Piezoceramics, Lodge Ignition, Sensorex, Vibro-Meter and Wilcoxon Research - whose portfolios form the basis of product lines offered by todays Meggitt Sensing Systems. Meggitts Endevco range of piezoelectric, piezoresistive, Isotron and variable capacitance accelerometers, piezoresistive pressure transducers, acoustic sensors, electronic instruments and calibration systems ensure critical accuracy and reliability within aerospace, automotive, defense, industrial, medical, power generation, R&D, space and test and measurement applications. Endevco and Isotron are registered trademarks of the Meggitt group. All other trademarks are property of their respective owners.
