Professional Leak Detection Kit for Oil-Based Fluid Systems
At the heart of the kit is the OPTI-LUX™ 400 — a state-of-the-art, LED leak detection flashlight that emits less visible light so industrial fluid leaks are easy to spot. This powerful unit features a high-output violet light LED that causes fluorescent dyes to glow far more brilliantly and with greater contrast than with standard blue light inspection lamps, revealing the exact source of every leak. Its power is comparable to high-intensity 150-watt lamps and it has an inspection range of up to 25 feet (7.6 m) or more.
The kit also includes an 8 oz (237 ml) twin-neck bottle of patented OIL-GLO™ 44 concentrated fluorescent dye, an 8 oz spray bottle of GLO-AWAY™ dye cleaner, an AC/DC charger, dye treatment tags and fluorescence-enhancing glasses. All of these components are conveniently packed in a rugged carrying case.
part2
For more information about the Spectroline® OLK-441 Leak Detection Kit, call 1-800-274-8888. Outside the United States and Canada, call 516-333-4840. Website at www.spectroline.com.
