True UV LED Flashlight for Industrial Leak Detection
The OPTIMAX 365 utilizes ultra-high intensity LED technology to produce a nominal steady-state UV-A intensity of up to 50,000 µW/cm² at a distance of 6” (15 cm). Powered by a rechargeable NiMH battery, it provides 90 minutes of continuous inspection time between charges. The LED lifetime is 30,000 hours.
The OPTIMAX 365 is extremely lightweight and compact, weighing just 11.8 ounces (335 g). Its ergonomic design provides ultimate comfort and freedom of movement during inspections. The flashlight has a corrosion-resistant anodized lamp body, which makes it perfect for industrial use in the field or plant. Just the push of a button turns the lamp on instantly at full power!
The OPTIMAX 365 comes with UV-absorbing spectacles, a belt holster and smart AC and DC battery chargers, all conveniently packed in a padded carrying case. The AC charger is available in 120V, 230V, 240V or 100V versions.
For more information about the Spectroline OPTIMAX 365, call toll-free 1-800-274-8888. Outside the United States and Canada, call 516-333-4840. Website at www.spectroline.com.
