Ultra-Portable Technology Breakthrough in Leak Detection
Designed for operation and maintenance personnel to perform frequent valve checks in their units, Valve-Squeak is an easy-to-use, throughvalve loss detection system.
Small enough to fit in your pocket, Valve- Squeak isolates leaks of any size in any valve and can save you thousands, if not millions, of dollars.
Find losses, before they grow Simple Operation. . .a green light shows a ‘no leak’, a yellow LED bar graph shows a ‘small to very large leak’. Once a leak is identified, a VPAC unit can be used for quantification.
Valve-Squeak has high noise and vibration immunity and is Intrinsically Safe for use in hazardous, gaseous environments that require Class I, Div 1, IIC, T4. (Currently only meeting US certifications.)
Download a PDF brochure at http://www.pacndt.com/products/leak%20detection/ValveSqueak_5132.pdf
