Yokogawa Releases SensPlus Note, an OpreX Operation and Maintenance Improvement Solution
[Tokyo, Japan - November 26, 2019] - Yokogawa Releases SensPlus Note, an OpreX Operation and Maintenance Improvement Solution for the Digitization of Field Data Using Mobile Devices.
Yokogawa Electric Corporation (TOKYO: 6841) and MetaMoJi Corporation announce that they have jointly developed SensPlus Note, a low cost and easy to implement solution for the digitization of plant data on mobile devices. SensPlus Note, a solution in Yokogawa's OpreX™ Operation and Maintenance Improvement family, improves the efficiency and quality of maintenance work and the precision of post-maintenance analyses by enabling data from plant field work to be used more efficiently. This solution will be released in all markets worldwide on January 31.
SensPlus Note
Development Background
A wide variety of equipment and devices from different manufacturers are used in plants. Each has a specific set of maintenance procedures and check items, and this work is performed as set out in manuals, check lists, and other documentation. While it would improve efficiency and help to ensure that this work is done correctly if field maintenance data could be shared and analyzed in real time, this is not possible in plants where such data is written down on paper documents. To address this need, Yokogawa and MetaMoJi have jointly developed the SensPlus Note solution for the digitization of field maintenance data on mobile devices. This solution draws on Yokogawa's plant operations know-how and MetaMoJi's proven expertise in developing business applications for mobile devices.
Features
The SensPlus Note solution consists of a data input application and a cloud platform. Data input using this application is digitized and uploaded to a cloud server, where it can be analyzed using other software. The mobile application is based on MetaMoJi's GEMBA Note, which is an advanced digital notebook that was developed to support maintenance at construction and manufacturing sites.
- Digitization and real-time sharing of information, with intuitive operation
With the SensPlus Note solution, text input using a pen or keyboard, videos, still images, and audio recordings can all be easily entered on the same form and linked to a device management ledger. This saves time and provides all the information in one place that is needed to know precisely what is happening in the field. Once such information is input into GEMBA Note, it can be shared with other personnel, drastically speeding up loop checks* and other tasks that require multiple operators to coordinate their efforts. - Ability to install additional server applications for statistical analysis and other operations
With SensPlus Note, data is uploaded to a cloud server, where it can be viewed and managed using a web portal. With its ability to store data collected over long periods of time, this platform is ideal for both preventive and predictive maintenance. Applications for the statistical analysis of field and plant operational data and other operations can be added to the platform as needed to assist in identifying failure causes and improving work procedures.Yokogawa will continue in its efforts to expand the lineup of applications that can be used with the SensPlus Note solution.
Major Target Markets
Manufacturers
Applications
- Communication between central control rooms and plant personnel, and between personnel at different plants
- Communication between field personnel and third parties, such as the help desk of a plant equipment manufacturer
- The analysis of stored data to improve maintenance and manufacturing operations
*Such tests check the communications link between devices by generating a test signal and verifying that is received.
About OpreX
OpreX is the comprehensive brand for Yokogawa's industrial automation (IA) and control business. The OpreX name stands for excellence in the technologies and solutions that Yokogawa cultivates through the co-creation of value with its customers, and encompasses the entire range of Yokogawa's IA products, services, and solutions. This brand comprises the following five categories: OpreX Transformation, OpreX Control, OpreX Measurement, OpreX Execution, and OpreX Lifecycle. SensPlus Note is an OpreX Operation and Maintenance Improvement family solution in the OpreX Lifecycle category. For its development of products, services, and solutions in this category, Yokogawa tapped its extensive experience in working closely with customers to optimize operations and maintenance over the entire plant lifecycle.
With this brand, Yokogawa will deliver integrated solutions that address specific needs and support its customers in their efforts to transform and grow their businesses.
About MetaMoJi Corporation
MetaMoJi is a premier application developer offering an advanced suite of products designed to be used by consumers, business and education.
MetaMoJi is committed to producing applications that help people perform tasks more efficiently, allow organizations to improve their processes and deliver a consistent user experience across multiple mobile devices and platforms. Recent awards include a winning place at the 2015 International Business Awards, two Envisioneering awards at CES 2014, and Tabby and Appy awards.
About Yokogawa
Founded in 1915, Yokogawa engages in broad-ranging activities in the areas of measurement, control, and information. The industrial automation business provides vital products, services, and solutions to a diverse range of process industries including oil, chemicals, natural gas, power, iron and steel, and pulp and paper. With the life innovation business, the company aims to radically improve productivity across the pharmaceutical and food industry value chains. The test & measurement, aviation, and other businesses continue to provide essential instruments and equipment with industry-leading precision and reliability. Yokogawa co-innovates with its customers through a global network of 113 companies spanning 60 countries, generating US$3.6 billion in sales in FY2018. For more information, please visit www.yokogawa.com .
The names of corporations, organizations, products, services and logos herein are either registered trademarks or trademarks of their respective holders.
