Why Your Preventive Maintenance Program Isn’t Working
In the chart below we find PM labor hours flat however emergency labor hours rising which indicates the PM program is not effective.
Fig 1
Have you ever heard of "killer PMs"? These are PMs which are intrusive and are known to quite commonly cause premature failure of an asset. One such example might be taking a pump out of service to inspect coupling shaft alignment. Consider carefully that this inspection could be easily performed using infrared thermography or vibration analysis without shutting down the pump. Have you ever seen someone lubricate an electric motor with sealed bearings? These PMs sound unnecessary. Yet these things happen every day.
Fig 2
PMs can also absorb resources which could be used for work that would actually improve your reliability. Remember, the challenge of reliability is the detection of a defect early enough that a part or equipment change out or repair can be planned and scheduled in a proactive state.
The example below displays the P-F Curve where "P" is the point at which an abnormality begins (defect). The key is that we want to identify a defect (potential failure) as early as possible so we have the time to plan, schedule, replace or repair the item before it fails. Point "F" is the point of functional failure. This is where the item can no longer deliver its intended designed function. At this point there is typically a very small amount of time before total failure where catastrophic damage could occur, which is not good unless Run-To-Failure (RTF) is part of our maintenance strategy. If RTF is your maintenance strategy for specific equipment, contact me and let's talk about this issue.
Fig 3
In the graphic above, it is important to notice that Predictive Maintenance allows one to detect a defect closer to "P" than Preventive Maintenance. We call this on-condition monitoring.
Do you realize that most Preventive Maintenance programs have not been engineered, they have just evolved? With every regulation or component failure, both the number of PM tasks and the frequency of the tasks being executed increases, until it consumes 30%-50% of your workforce and you are lulled into the false sense of security that you have evolved into a Best Practice or World Class organization." Let's be clear, it is impossible to evolve into Best Practice; it must be carefully engineered.
In fact, after numerous benchmarking studies, data states factually that most maintenance organizations are doing almost exactly the same type of maintenance they've always done. Now here's the scary part: a closer look at all Preventive Maintenance (PM) tasks reveals that on average:
  • 30% don't add value and should be eliminated
  • 30% should be replaced with Predictive Maintenance (PdM) tasks
  • 30% could add value if re-engineered
What that means to you is that less than 10% of your PMs are truly adding value as written. Or in other words, potentially 90% of your PM tasks should be eliminated or changed. What's worse, when you conduct unnecessary, invasive maintenance, you actually introduce variability and potential defects into your asset and process reliability? That's right! You are actually causing some failures and you don't even know it!
Fig 4
What to do about the problem?
Striking the right balance of Preventive and Predictive Maintenance is absolutely necessary and it offers a rare opportunity to save millions of dollars through:
  • Lower maintenance costs
  • Lower spare parts inventories
  • Lower energy consumption
  • Better safety performance
  • Increased throughput capacity
Fig 5
Achieving these results is not easy. For starters, you need to have a common vision, a basic implementation strategy, and a clear understanding of what's required for success. Let's look at the four most important steps you can take to begin achieving your reliability goals.
  1. Receive training in PM/PdM Best Practices.
  2. Update your functional hierarchy so that you have a clear understanding of the machines in your facility and their component configuration.
  3. Conduct a criticality assessment on your assets. This assessment is used to help determine maintenance strategy, prioritize work orders, and make better overall risk management decisions. (Send me an e-mail if you would like more information on this topic.)
  4. Develop a complete understanding of the failure modes that are present or may be present in your components. These failure modes come from two places: 1) the inherent design of the machine; and 2) the operating context in which they are used on a daily basis.
  5. Perform a Preventive Maintenance Evaluation (PME) where you identify each PM Task and any connection it may have to a failure mode you are experiencing. Are the PMs causing the failure or addressing it? If they aren't addressing and reducing failures, then they add no value.
  6. Then, believe in the outcome of your PME. If it says a PM adds value, do it! If it shows it doesn't, then re-write/re-engineer it so it does, re-assign it to the appropriate PdM Technologies or get rid of it! See the chart below. This process frees up resources for use in proactive maintenance.
Fig 6 Fig 6
If a company is not seeing results from their current PM Program then it is time to change. Make it happen today. If you would like a one-hour webinar on the topic send me an e-mail at rsmith@gpallied.com. I also have a Tool Box Training Session on Failure Modes Driven Strategy you may enjoy. Just let me know if you are interested. Make something happen!
Ricky Smith
Ricky Smith, CMRP, CPMM, is the Senior Technical Advisor for Allied Reliability. Ricky has over 30 years in maintenance as a maintenance manager, maintenance supervisor, maintenance engineer, maintenance training specialist, maintenance consultant and is a well known published author. www.gpallied.com
