IMI Sensors Launches New IO-Link Piezoelectric Accelerometer, Model 674A91
April 8, 2024 DEPEW, NY - IMI Sensors, manufacturer of industrial vibration monitoring instrumentation, announced the release of Model 674A91, a fully programmable accelerometer featuring IO-Link universal protocol. Designed with piezoelectric ICP® technology for the most precise and comprehensive machine health data, this state-of-the-art sensor redefines the possibilities of industrial monitoring and control.
Model 674A91 is intended to be stud mounted to an industrial asset with the 4-pin M12 connector directly cabled (point to point) to an IO-Link Master. An IO-Link Master is a multichannel device that provides 24 VDC, controls the communication of the sensor, and provides information direct to the factory network. IO-Link compatibility offers:
  • Easy communication with your current control system via EtherNet/IPâ„¢, Profinetâ„¢, Modbusâ„¢, OPC UAâ„¢, or MQTTâ„¢ and others.
  • Measurements and averages at user-specified intervals
  • Full spectrum data processing to trend for condition monitoring
  • Maintenance alerts when peak values or sensor specifications are exceeded
Model 674A91
With a frequency range up to a full 10kHz, Model 674A91 offers much more effective fault detection than most comparable MEMS based devices on the market today. The 50g peak accelerometer boasts an impressive array of features for insight into equipment health, with functions including true peak acceleration, RMS acceleration, RMS velocity, crest factor and temperature output.
For all technical inquiries and application support, please contact Matthew Negaard, Business Development Manager IMI Industrial and Digital Sensors at MNegaard@pcb.com.
About IMI Sensors
IMI Sensors is a global designer and manufacturer of industrial vibration monitoring instrumentation, including accelerometers, vibration transmitters, switches, cables and accessories. Our industrial sensors are used to spot imbalance, bearing faults, and misalignment by measuring machine vibration for early fault diagnosis, reducing downtime and protecting critical machinery. For power generation and energy applications requiring precision measurement, IMI also offers pressure sensors and accelerometers. With a worldwide customer support team, 24-hour sensor line, and a global distribution network, IMI is committed to Total Customer Satisfaction. IMI Sensors is a division of PCB Piezotronics, Inc.
