Manage basics for Tririga Pros - Andrew Tess
This presentation provides TRIRIGA professionals with a foundational guide to managing IBM Maximo. The speaker compares the architecture of both platforms, detailing Maximo's evolution toward the React-based Maximo Application Framework (MAF) and noting that Maximo's logic resides primarily within Java code. The session highlights critical differences in data modeling, explaining that Maximo utilizes database tables and standard objects that require a specific "admin mode" to apply structural database changes, contrasting with the publish and revise cycles found in TRIRIGA. Furthermore, the presentation emphasizes Maximo's significantly simplified workflow design, which features a straightforward, single-run process that avoids cascading synchronization issues. Finally, the speaker outlines Maximo's application security model, which is controlled by signature options, and introduces the robust Maximo Integration Framework for mapping data and managing REST API connections.
