Make It Visual: How Seeing Transforms Facility Reliability
When leadership says "Go and do Lean," most facility managers face the same question: Which tool should I use? It's a fair question, but it's also the wrong starting point. The real journey to operational excellence doesn't begin with selecting tools, it begins with clarity of vision and an understanding that Lean is fundamentally a mindset, not just a collection of techniques.
The Foundation: Understanding Lean in Context
Lean Maintenance is all about boosting asset reliability through five key principles: Gemba (go to where the work happens), Kaizen (continuous improvement), Standard Accountability Processes, Waste Elimination, and Visual Management. Visual tools aren’t just charts. They are a way to make problems and progress obvious so teams can act faster and smarter.
Gemba Walks: Seeing the Work
Gemba walks are structured observations at the point of work. They helped us spot inefficiencies like unclear roles, poor planning, and low wrench time. These walks revealed gaps between leadership’s expectations and what was really happening on the ground. By making Gemba a regular habit, we gained insights that no dashboard could provide.
5S: Visual Order in Action
The 5S method (Sort, Set in Order, Shine, Standardize, Sustain) turned cluttered spaces into organized and efficient work areas. It’s not about occasional cleanups. It’s about making order part of the daily routine. With visual cues and designated spots for tools, we cut down on delays and boosted productivity.
Work Execution Management: Clarity Across Roles
Work Execution Management helped us define roles, standardize workflows, and clean up CMMS data. Mapping out the process from initiation to review made it easier to spot waste and nearly doubled our wrench time. Everyone knew what was expected and where things stood.
PM Optimization: Smarter Maintenance
Preventive Maintenance Optimization helped us align job plans with what assets actually needed. By grouping similar equipment and analyzing failure patterns, we eliminated unnecessary tasks and moved toward condition-based maintenance. The result was thousands of hours optimized and more work handled in-house.
Task 12000: Technician Feedback Loop
We added Task 12000 to every job plan. It’s a simple prompt asking technicians to flag issues with work instructions. Their feedback was reviewed and used to improve CMMS data. This small change created a powerful feedback loop that improved accuracy and execution.
Visual Dashboards: Data That Drives Action
We rolled out dozens of new dashboards and retired outdated ones. These visuals made it easier to track key metrics, spot issues early, and make better decisions. By embedding dashboards into our daily routines, we made accountability and improvement part of the culture.
Operational Excellence: Tools for Progress
We used two tools to keep momentum going. The A3 problem-solving framework helped us tackle complex challenges. The Continuous Improvement idea system captured over 200
ideas from the team. Both tools made progress visible and encouraged collaboration.
The Results: What Changed
Here’s a snapshot of the impact:
More importantly, the culture shifted. Teams embraced training, shared insights, and built a foundation for sustainable reliability.
Lessons Learned: Strategy Before Tools
Start with strategic goals, not tools. Language matters. How we talk about Lean shapes how it’s received. When in doubt, visualize. Making work visible accelerates understanding and action. Lean is a journey, not a destination, and visual tools are the compass. The transformation from reactive firefighting to proactive reliability doesn't happen overnight. It requires executive sponsorship, frontline engagement, disciplined methodology, and persistent patience. But when organizations commit to this journey,not as a project with an end date, but as an evolving way of working, the results reshape not just maintenance performance, but safety, cost, morale, and ultimately, competitive advantage.
The question isn't whether your organization can afford to pursue Lean maintenance. It's whether you can afford not to.
Durlove Mohanty
Durlove Mohanty is Sr. Director leading the Center of Excellence organization, with over 15 years of experience in facilities and maintenance operations. With a background in Mechanical and Industrial Engineering, he specializes in Lean transformation, reliability engineering, and smart facilities management. Durlove holds certifications as a Lean Six Sigma Master Black Belt, Certified Reliability Leader (CRL), and LEED Green Associate. He is passionate about driving operational excellence and leads cross-functional teams to deliver sustainable, data-driven outcomes across complex environments.
