7 Things to Do When Using an Induction Heater for Bearings and Other Workpieces
  1. Make sure the surfaces of the vertical posts are clean.
  2. Improve the contact between the vertical post and the crossbar by applying a light coat of Vaseline or grease to the contact surface of the vertical post.
  3. The temperature probe should always be placed on or as close as possible to the inner race or ID of the workpiece being heated.
  4. When possible make sure a second probe is placed on the outer race or OD of the workpiece being heated to also track the temperature of the OD, in line with the ID probe.
  5. For the most efficient heating, always use the largest possible crossbar that will fit through the ID of the workpiece being heated. Stacking of multiple crossbars is permissible.
  6. It is not a requirement that the workpiece must touch the crossbar(s). Just so long as the bar goes through the bore (ID) someplace.
  7. Most important of all is that the workpiece being heated always be automatically demagnetized. Any induction heater that does not do this automatically COSTS you money instead of saving it.
Learn more about SURETHERM Induction Heaters
Tip provided by
