Did your facility recently undergo an Arc Flash Risk Assessment?
Did some of your applications receive a label saying: "Danger - Do Not Open - No PPE Available?"
How will your PdM program monitor these high-incident energy assets? Infrared (IR) scans, visual inspections and ultrasound scans are typically performed by opening the equipment. Inspection windows (IR Windows, visual inspection windows and ultrasound ports) allow PdM Engineers to troubleshoot energized components while leaving the equipment closed.
Inspection windows help facilities comply with insurance mandates for inspections, while complying with regulatory mandates for safe work practices.
Learn More
Tip Provided By:
