Avoid These 3 Common Mistakes When Lubricating Bearings
  1. Lubricating based on TIME instead of CONDITION
  2. Over and Under Lubrication
  3. Using a "Listen-Only" Ultrasound Instrument
Ultrasound provides you with the data to shift from calendar based to on-condition based scheduling. It tells you when friction levels elevate above acceptable baseline, and it guides you as you apply just the right amount of grease to get things back to normal.
Learn More
Tip Provided By: Allan Rienstra, SDT Ultrasound Solutions
SDT logo
