A routine maintenance task, normally an inspection or testing task, designed to determine whether an item or component has failed. A Failure finding task should not be confused with an on-condition task which is intended to determine whether an item is about to fail. Failure finding tasks are sometimes referred to as functional tests.
Tip excerpted from: The Professional's Guide To Maintenance And Reliability
Get your copy today
