The analysis of vibration monitoring data to monitor the characteristic changes in rotating machinery caused by imbalance, misalignment, bent shaft, mechanical looseness, faults in gear drives, defects in rolling-element bearings, and/or defects in sleeve bearings.
Tip excerpted from: The Professional's Guide to Maintenance and Reliability Terminology by Ramesh Gulati, Jerry Kahn and Robert Baldwin
The Professional's Guide Book Image
