Desiccant Breathers – Find the Right Fit for Maximum Life
Every manufacturing environment is different and many environmental variations can influence the life of a desiccant breather. In order to install the correct desiccant breather on equipment applications the maximum flow rate, gallons of lubricant in the equipment, and ambient environment of the application must be determined. Consideration of these factors before installation will allow the breather to achieve its best possible lifespan and optimal equipment protection.
Find the right fit with the Breather Sizing Wizard
Tip Provided By: Elizabeth Pruitt, Product Marketing Manager
Des-Case logo
