Often times an inspection area is contaminated by stray parasite noise coming from a continuous source. For example, a large leak on a valve stem that is already tagged but not yet fixed. Try blocking this disturbance by fixing a small cardboard box over the valve. Presto! All that parasite noise is now contained inside the box and you are free to finish surveying the area.
Learn More
Tip Provided By
