Whether you receive oil in bulk, tote or drum, new oil is typically 4-8 times dirtier than recommended for critical applications. Watch this maintenance tip to find out how you can prevent contamination when transferring oil from storage to the machine.
Learn more atÂ
descase.com
Tip Provided By:Â
