As the load on an electrical component rises, so does the temperature. An even load on each phase of a three-phase system, should result in a uniform thermal pattern on all three phases. Problems may be indentified when the overall component ad conductor temperature is too high or an unbalanced condition is identified by the phase not displaying a balanced and equal thermal pattern or temperature.
Tip provided by the Academy of Infrared Training
