Infrared inspections of mechanical systems can be challenging. A working knowledge of the machinery or component is absolutely necessary in order to successfully interpret these images. This is especially true when inspecting hydraulic systems which are some of the most widely used pieces of equipment in plant operations.
Click here to learn more about phase to phase resistance.
Submitted by: Jim Fritz, The Snell Group
