“I like the idea of IR windows, but I just can’t see enough!” If this sounds familiar, you’re in good company. Thermographers’ second most common concern about IR windows has long been the restricted field of view of smaller IR windows.
Simply put, sometimes you just need to be able to scan horizontally or vertically to see around obstructions or to view multiple targets that are close to the enclosure panels.
The solution: Exiscan Large-Format Inspection Panels.
Windows apertures measure 10”, 15” or 20” wide
IR, visual and ultrasound inspection in one panel
Unrivaled durability and resilience – what you expect from Exiscan
Learn More
Tip provided by:  Exiscan
