The 3-D BullsEye® – Maintain the Correct Oil Level in Your Equipment with a 360° View
The 3-D BullsEye allows immediate and accurate visual oil level monitoring from virtually any angle. Engineered to outperform and outlast traditional viewports, the inherently strong material provides excellent impact, chemical and UV resistance.
To prove the 3-D BullsEye is hard, strong, and tough we tried to destroy it, and failed. See the results.
Des-Case 3-D BullsEye
Put one to the test on your machinery. Learn more at http://www.descase.com/visual-oil-analysis/3d-bullseye.
Tip Provided By: Des-Case logo
