Reliability Engineering for Maintenance Mitigating Asset Failure Consequences Using Root Cause Analysis Reliability Engineering for Maintenance Root Cause Analysis play icon Learning Point Takeaways: 1) How Root Cause Analysis fits in the PAS 55 specification2) An approach for identifying the root cause of failures3) An approach for handling root causes to mitigate consequences of asset failures and defects
