Using IIoT to Become a More Predictive Organization: Case Study - GE Appliances
IMC-2017 Learning Session - 40:15
by Scott Shaver, GE Appliances, and Bob Stallard, Viziya Corp
Do you know what to do with your IoT data? Are you having issues collating and understanding your data so it is actionable? Are you finding it difficult to streamline your work management process because you can’t connect the data to the right systems?
You are not alone. Imagine an IoT product that is being used successfully by several Fortune 1000 companies that addresses the data intelligence gap, and delivers on the promise of IoT to:
  • Connect your sensor data to your CMMS
  • Make that data actionable: i.e. generate work orders, work requests, assign priorities, trigger events
  • Write the data back to the historian
  • Ultimately, create a more predictive maintenance organization
