Exiscan Infrared Windows
Eliminate Risks
Comply with electrical safety mandates like NFPA 70E and CSA Z462, by providing safer access for thermographers to trouble-shoot electrical switchgear, and other electrical applications. Because the Exiscan IR windows maintain a NEMA/IP seal while thermographers perform IR surveys, personnel are separated from energized electrical conductors and circuit parts per electrical safety mandates.
The non-intrusive inspection process controls risk by virtually eliminating the possibility of worker-initiated electrical hazards during inspection, making them a natural choice for any facility that places a premium on risk mitigation and safe work practices. Patent pending design features create "bullet-proof" protection to guard against blast effects when the window is closed.
IR Windows are Lean & Green
Work process improvements resulting from closed panel inspections are 75% to 95% more efficient than open-panel inspections. The result is an almost immediate ROI -- in as little as the first inspection cycle. The simplicity, safety and efficiency of the inspection means that more frequent and meaningful inspections become the norm so that energy wasting faults are systematically banished from your systems. More efficient use of labor, more efficient use of energy... Exiscan IR windows will help your facility see GREEN in more ways than one.
Exiscan IR Windows are made with pride and quality in America. What are you risking by not using them? And at what cost?
