Figure 1: Equipment failure is not an option in surface mining operations
Around-the-clock operation of heavy equipment in harsh, gritty conditions is the nature of the coal mining and production business. Equipment failure is not an option for an industry that services customers around the world. Some of the components cost hundreds of thousands of dollars each and production downtime losses can be immeasurable.
Reliability has long been in focus at one surface operation in the U.S. that produces tens of millions of tons of coal each year. Condition monitoring of equipment began there 15 years ago to provide early detection of deterioration and avoid costly failures. By 2013, nondestructive testing (NDT) procedures, including oil analysis, vibration monitoring, ultrasonic testing, thermography and walk around visual inspections, were in use.
Early that year, the company took steps to further improve reliability and reduce costs. By 2015, the company’s various cost initiatives saved $525 million and reduced capital investments to $194.4 million. The journey that began with oil analysis – the company’s largest condition monitoring expenditure – is now being expanded and rolled out globally.
Oil is the low-hanging fruit
The established oil analysis program monitored mining equipment, such as earth moving draglines, electric mining shovels, ultra class haul trucks, track dozers and motor graders. Certain systems within the coal processing plants were also monitored. Approximately 4,000 individual oil sample points were taken as often as every two or four weeks.
Though it was helpful in managing machine health and meeting component replacement targets, the existing oil analysis program lacked efficiency and visibility. Information was tracked using methods ranging from a computerized maintenance management system (CMMS) to spreadsheets, technician notes and stand-alone software programs.
The spreadsheet tracking of high sample volumes was particularly prone to errors. There were incidents of inaccurate sample labeling and tracking, lost samples, inconsistent return times and overdue oil sample condition assessments. Greater automation, control, accountability and “whole picture” analytics were desired.
Following a region-wide process review in 2013, the decision was made to standardize and consolidate on a cloud-based reliability information management system for oil sample analysis management, including direct communication with the oil lab.
The Web-based approach that was selected provides a more efficient and accurate oil sample identification and tracking process. Oil sample scheduling is managed within the reliability information management system and the cloud-based, interactive results are transferred directly from the oil lab and made available to tribologists at each mine.
From a web browser, the coal company’s analysts are able to:
  • Review the full details in an interactive sample report;
  • Apply customized alarm sets that are different from the lab’s alarms;
  • Create trend charts for data parameters;
  • See the lab’s analysis comments and add new comments or questions;
  • Create a condition entry for the asset location to escalate problem visibility.
Big picture reliability comes into focus
Details of problems from flagged oil samples and the recommended maintenance actions are posted to a browser-based status condition status dashboard. The dashboard, easily visible to a wide audience of authorized users, lists all known problems of an asset by severity, the number of days the problems have been open and the work order numbers.
The coal company soon recognized that its other condition monitoring technologies could also integrate with this dashboard. This would eliminate the many hours spent gathering reliability information and metrics from numerous stand-alone databases and assembling and communicating it in spreadsheets. Moreover, it would provide a complete and readily accessible picture of asset health.
The company chose to centralize all condition problems found via oil analysis, vibration analysis, ultrasound analysis, thermography and walk around inspections on the dashboard, which is part of its reliability information management software. This gives technicians and managers a single platform from which to track and manage all known conditions that can impact the reliable performance of equipment.
Partnership approach
To best meet its improvement objectives, the coal company worked jointly with the reliability software provider to map out key processes and adapt oil sample analysis management and reliability information management solutions to its business needs.
A jointly developed interface imports current meter hours twice daily from the company’s CMMS and a budgeted life percentage calculation was developed. This allows the integrated condition status report to show the status of individual components and where they are in terms of their lifecycle relative to the targeted replacement interval.
An automated task system for oil sample selection and labeling was also developed. Previously, the machine run hours, component service hours and lube hours on sample labels were assigned manually and prone to errors. When the company’s oil techs didn’t adapt well to the new electronic system for generating labels, the responsibility was shifted to water spider personnel (staff who keep production materials in stock at point of use so production personnel can focus on asset tasks that create products or provide services).
Another early challenge was gaining support from the oil lab. The lab had to review its internal processes for managing oil analysis data and upgrade its systems to support electronic data transmission. Ultimately, the new system helped to improve the coal company’s relationship with the lab. It streamlined some of the oil lab’s work and actually reduced or eliminated its need for manual data entry, which, in turn, reduced the potential for errors.
For this company, the improved interaction between technicians, analysts and lab personnel is increasing the accuracy and control of the mine’s reliability program. Maintenance personnel can more effectively manage machine component health and have greater insight into the highest priority work, the expected useful life of the assets and complete machine health histories.
Global program rollout
Due to the western region’s success, efforts are underway to standardize all NDT and reliability procedures across all operations in the company’s global platform, which vary in size and scope. This involves:
  • Using both Web-based oil sample analysis management and reliability information management software as the single source for machine health reporting and analytics, while using the CMMS for scheduling and costing;
  • Formalizing the methodology used to determine which NDT process or processes to employ based on the equipment type;
  • Standardizing the associated NDT strategy and frequency in order to maximize problem detection and apply the appropriate corrective action;
  • Standardizing the tracking of value, cost savings and avoidance, route adherence, condition assessment procedures, and asset health and component condition reporting.
Upgrades and system improvements are an ongoing effort and the coal company continues to work closely with the software provider on this. For example, they are currently developing a CMMS notifications link within the reliability software’s condition status dashboard. They also plan to develop a senior assets review using the budgeted life status percentage to assist in risk-based assessments by the maintenance director, reliability manager and planners.
Meanwhile, the company continually adds more reliability processes, such as additional vibration and thermography routes, expanding the number of systems and components that are tracked and monitored. The company is also using mobile devices to capture field measurements and inspection data where problems found by inspection personnel can be integrated on the condition status dashboard.
Future plans include implementing a full system interface with the reliability information management software and the CMMS, and using more of the mobility, repair tracking and root cause failure analysis (RCFA) case management features available within the software.
By moving the entire organization from spreadsheets to a common reliability platform in the Cloud, the company is setting the stage for continuous improvements in asset performance, uptime and operational efficiency.
Steve Marshall & Forrest Pardue
Steve Marshall is the Preventative Maintenance Coordinator at Xanterra, Inc. in Wyoming. He has more than 30 years of experience in the mining industry. As an accredited Six Sigma Black Belt, he has led several successful lean system improvement projects and reliability improvement initiatives at various companies, including Peabody Energy and BHP Billiton. www.xanterra.com
Forrest Pardue is President of 24/7 Systems. He has worked in the field of vibration analysis and production maintenance for the last 25 years. In 1997, he co-founded 24/7 Systems, a company focused on the development of reliability information management software and services, to facilitate the measurement, management and improvement of plant machinery reliability. He earned a BSEE from North Carolina State and an MBA from Lynchburg College.
www.TF7.com
Download Article
