In the late 1990s, handing your entire IT infrastructure to an outside vendor sounded reckless. Why would a Fortune 500 company give away its technology backbone? The answer was simple. Technology wasn't their core business. IBM Global Services, EDS, and Accenture proved enterprises could shed the operational burden of IT and get better service from specialists who did nothing else. By the early 2000s the argument was over. TCS, Infosys, and Wipro scaled fast after Y2K, proving even mission-critical work could sit outside if governance and metrics held up.
Facilities management has followed the same arc, about twenty years behind. What started as janitorial contracts and reactive maintenance has turned into a multi-billion dollar industry. CBRE, JLL, Cushman and Wakefield, and Sodexo aren't vendors anymore. They're operating partners inside the most critical parts of global enterprise. After fifteen years running FM and operational excellence programs across pharmaceutical, automotive, and financial services sites, the catalyst is clear. It's reliability engineering.
What the Old Model Cost
For most of the twentieth century, FM was reactive. Equipment failed, someone called maintenance, parts got sourced, systems came back up. The industry trained itself to respond, not prevent. It was misaligned from the start. A pharmaceutical manufacturer running cGMP cleanrooms isn't in the HVAC reliability business. A global bank running trading floors isn't in the chilled water business. Both spent real money and management attention on exactly those problems.
The economics were bad in a way that didn't show up cleanly on a P&L. Unplanned downtime in regulated manufacturing runs into hundreds of thousands of dollars an hour. Deferred maintenance builds up quietly. By the time the real cost is visible, the case for a specialist has already made itself.
Where Reliability Engineering Changed Everything
The providers who won didn't win on contract terms. They won by building reliability engineering into how they operate, delivering results internal teams couldn't structurally match.
RCM moved maintenance off calendar-based PM schedules and onto actual failure modes, consequences, and detection capability for each asset in its real context. On a large pharmaceutical account, the gap between a conventional PM program and a properly built RCM strategy can be millions in annual maintenance efficiency, with fewer critical failures. That's not a tune-up. It's a different way of managing asset risk.
Condition-Based Monitoring brought industrial predictive tools into the built environment: vibration analysis on rotating equipment, thermography on electrical panels, ultrasonic leak detection, oil analysis on chilled water compressors. A provider who can show a sustained shift in planned-to-unplanned ratios is delivering something a reactive internal model can't.
CMMS-driven asset management gave both sides real visibility into MTBF, MTTR, PM compliance, and backlog health. That's what made outsourcing governable. Lean and Six Sigma gave us the discipline to hold those gains after transition.
Visual management ties it together. I wrote about that in Make It Visual previously. Gemba, 5S, standard work, dashboards. When you make the work visible, problems and progress become obvious and teams act faster. That program has kept compounding since. We're now past 4,000 maintenance hours optimized, with more than $2M in savings through Lean initiatives. The tools mattered less than the visibility.
Where I've seen that shift land, the pattern holds. Organizations that govern outsourced FM with the rigor they apply to core operations get real value. The ones treating it as procurement don't.
The Pharmaceutical Proof Point
Nothing shows the maturity of FM outsourcing better than pharmaceutical manufacturing. FDA 21 CFR Part 211, EU GMP Annex 15, and ISPE guidance set documentation and environmental reliability requirements that make reactive FM not just inefficient but legally untenable. A critical utility failure doesn't just stop production. It triggers deviation investigations, 483 observations, and in bad cases consent decree exposure.
The providers with credibility here built operating systems where PM completion feeds batch release confidence, predictive findings feed risk-assessed change control, and environmental monitoring data gets trended next to asset health metrics to catch excursion risk before it becomes a GMP event. That's industrial asset management at its highest level, inside one of the most demanding regulatory environments there is.
What Enterprises Are Actually Buying
The common misunderstanding, especially from finance leaders looking through a cost lens, is that the enterprise is buying labor. It isn't. It's buying capability it can't economically build or sustain on its own. Reliability expertise accumulated across thousands of facilities. Technology platforms no single organization could justify alone. Continuous improvement infrastructure that pushes performance forward, not just defends a baseline.
Put simply, the enterprise is buying back its leadership bandwidth, while a specialist takes accountability for making the built environment reliable, compliant, and better every year.
The Invitation
That's what IT outsourcing delivered a generation ago. The companies that saw it early got the advantage. The ones that held on out of habit spent a decade catching up. FM is at that same inflection point, and the window is narrowing.
For reliability professionals reading this, the built environment needs exactly what you've spent your career building. RCM, CBM, FMEA, planned-to-unplanned discipline, asset criticality frameworks [none of it stops being relevant at the plant fence line]. The FM outsourcing industry has built the structure to deploy that expertise at scale. That's not a side opportunity. It's one of the most consequential places reliability work can go.
The question isn't whether FM outsourcing works. Fifteen years of program data answered that. The question is whether the reliability community steps in with the rigor the work deserves, and whether enterprise leadership governs it like the stakes are real.
Read Durlove's other publications: Make it Visual: How Seeing Transforms Facility Reliability
https://reliabilityweb.com/make-it-visual-how-seeing-transforms-facility-reliability
