Do gearboxes keep your assembly line moving?
Are hydraulics key to product production?
Is oil stored in totes or drums the future lifeblood of your machinery?
Put your hands up if you want to keep your plant running, not interrupted for maintenance. To do that, take care of the oil that takes care of your machines.
Replacing a standard breather cap with a desiccant breather:
  • Eliminates water contamination
  • Reduces abrasive wear
  • Improves lubricant performance and increases oil filter life
  • Reduces rebuild/replacement costs
Learn More
Tip Provided by:
