Additive for protecting lubricated metal surfaces against chemical attack by water or other contaminants. There are several types of corrosion inhibitors. Polar compounds wet the metal surface preferentially, protecting it with a film of oil. Other compounds absord water by incorporating it in a water-in-oil emulsion so that only the oil touches the metal surface. Another type of corrosion inhibitor combines chemically with the metal to present a nonreactive surface.
Tip excerpted from: The Professional's Guide to Maintenance and Reliability Terminology by Ramesh Gulati, Jerry Kahn and Robert Baldwin
View Book
