Work Execution Management Definition: Management of Change (MOC) Work Execution Management Preventive Maintenance The process of bringing planned change to an organization. MOC usually means leading an organization through a series of steps to meet a defined goal. Synonymous with change management.Tip excerpted from The Professional's Guide To Maintenance And Reliability
